- Mar 20, 2017
- 145
- Plaster
- Pentair Intellichlor IC-60
Currently I have a 30amp 220 circuit and a 20amp 110 circuit feeding the pad.
Please help me understand the electrical needs for the following:
I have an unused 50amp breaker in the main panel that can be repurposed to supply the above. Will that be enough?
I'm acquiring the new stuff a-al-carte and I haven't got the breakers yet. 2 x 20amp GFCI for the pumps and what else?
Finally, if the 50amp circuit is enough, will I be able to add the below given all the above?
1 - LED Pad light
1 - 12v LED Landscape lighting transformer
TIA
Todd
1 - 208-230v/12.4-11.2amps 3hp Pentair Intelliflo3 ~ filtration pump (NEW - replacing a 2hp Jandy single speed)_
2 - 208-230v/7.8-8amps 1.5hp Pentair Whisperflow WF-26 ~ sheers pump
3 - 120V/1.7amps Stenner
4 - 240v/5.6amps 2hp Polaris blower
5 - 220-240v/1amp Pentair IntelliChlor iC60 (NEW)
6 - Pentair LED Intellibrite pool, Pentair LED Intellibrite spa switched together
7 - Rheem 336A Natural Gas heater
8 - 110v convience outlet
9 - IntelliCenter i10ps (NEW)
1 - LED Pad light
TIA
Todd
