Hi everyone,
Found this site last year as new-to-us pool owners. It saved my sanity...thank you!
On Sunday, 5/15 we removed most of the winter muck off the top of the winter cover. We had the cover pulled back all but one corner (the pool looked beautiful!). Removed as much water and debris as possible then heave-hoed the cover out of the pool.
Well, what was remaining in the cover happily dumped into our pool. Leaf litter, bird poop, and lots of green (algae?).
We immediately added 2 gallons of 12.5% liquid chlorine. Then another gallon a couple of hours later. The water is cloudy now. Ran the filter for about 6 hours.
I've netted out piles of debris. There's still a bit but I can't get it with the net. And there's a lot of heavy (mossy/algae particles). I've swept the entire pool and I started vacuum to waste this afternoon.
I'm having a problem with vacuuming...within 30 seconds, the water flow stops. Flip the valve to backwash and it takes about a minute for the flow to return. I've done this 3 times and thought it best to stop and ask for some input.
Pics of pool (albeit, you can't see much) attached.
The vacuum attachment is similar to this:
Vacuum plate
I'm not sure what to do. Is the pool too dirty to run the filter? Should I run it for 24+ hours and see how much it can clear up? I do want to get the muck out of the bottom of the pool asap, but losing the water flow so quickly has me scratching my head.
Would it make sense to even test the water right now?
Thanks for any input you can provide!
Take care,
Tiffanie
Vacuum plate
Take care,
Tiffanie
