I inherited a pool this user and it turned into a swamp this summer. I was able to get the chemistry correct but I could see lot of dirt and pool stuck as green. I notice my pool pump water flow becomes slow whenever I use shock or green to blue products. Tried cleaning filters multiple times. But in no time i see the water flow going down. Filter pump valve is stuck so can't backwash. My pool robot is also not able to pick enough dirt. Can't see the bottom.Tried draining the pool 3/4 way(mistake?) and see lot of green smelly sludge at the bottom. Tried removing the sludge with pool net and it's not working. sludge is getting mixed in water and very small quantity i could pick. What options I have now. Should I rent a trash pump and drain all the way.
