So, when I got my pool installed, I programmed the pump to one of his filtration schedules matching my pool's volume of water.
Dan,
There is nothing wrong with your schedule at all.. But... The idea that you 'must' turnover x amount of water per day is just a myth..
We do not care if a pool owner
wants to turnover their water 100 times a day.. We just want everyone one to understand it is not a
reason to run your pump.
Reasons to run your pump, at a specific speed, are things like..
Generating the chlorine your pool needs if you have a SWCG or use tablets in a feeder.
Skimming the surface of your pool.
Making your spa work the way you want.
Making your water features work the way you want.
ETC.
In your case, I do not see any real issues.. But, we often see pool owners running their VS pumps at almost full speed, just because they think that turnovers are a
requirement to have a well working pool.
Chemicals are what keeps your pool clear and sanitized. The filter is not there to prevent algae, it is just there to capture the junk that falls into your pool and floats.. By the time Algae shows up in your filter, you have already lost the algae war..
