- Dec 26, 2019
- 1,848
- Plaster
- Pentair Intellichlor IC-40
If you have an IntelliFlo VS pump, it is controlled by serial cable and not a relay, so the IntelliFlo's AC power does not go through any relay. It is wired from the breaker directly to the pump.
Wait... Is this true? Why in the heck did my PB's electrician wire them through relays then?
I re-read the Intellicenter install manual and it does look like this is true, the best I can tell. I didn't pay much attention to that part since the power was already hooked up to the pumps. I ran the com cables to the pumps so I made sure to read that part.
Thanks
--Jeff
