- Sep 28, 2018
- 238
- Plaster
- Pentair Intellichlor IC-40
14ga galvanized steel tubing welded together. Lot of work but very happy with how it turned out.
Wet Bar Tour:
Full Pool Tour:
Put in dry wells on both sides a few years ago to deal with both side yards yard flooding once the pool was built. Kept a line for a sink ready knowing we would want to put one in eventually
Fortunately I had my very best helper. Always on the job site early every weekend. So early that she wakes me up when I'd rather sleep for another 15. Her little brother is due on Thanksgiving!
Used cold galvanizing spray over the welds to prevent them from rusting in the intense humidity
Frame built and inside painted
Gotta have paper towels near the sink!
Wife requested outlets for crock pots and warmers
I used cheap standard back-vented mini fridges and then added circulation fans inside them to stop the issue of some drinks being frozen while others aren't cold enough. Added a motion light while I was at it. Then there is a fan behind the fridge that pulls air through the cracks on the sides and top to cool the compressor and dump the air out through the vents
Couldn't find any standard sized pull out trash that would fit so I built this one out of angle steel and wrapped in aluminum. The top is PVC, used a table saw to hollow out a couple inches inside so that it hugs the trash can holding the bag in place.
Brand Man Rustler grill - very happy with it. Tons of storage and a dedicated corner so you're not in the way of everybody. 12 wheels so it's so easy to move under the patio if you want to grill while raining.
Wet Bar Tour:
Full Pool Tour:
