- Jan 7, 2012
- 2,117
- Plaster
- Pentair Intellichlor IC-60
AquaCal sells a condensation drain kit (STK0202) for around $100, but you can install essentially the same system with ~$5 of parts from the hardware store. It took me around 10 minutes to complete the job on my SQ150VS.
For parts, I installed a 1/2" MIP threaded fitting initially with a 1/4" barb for the drain tubing, but later upsized to a 1/2" barb. I installed a 13/16" x 5/8" rubber stopper to cap the drain hole on the opposite side.
For tools, you'll need to borrow or buy a 1/2"-14 NPT tap. The tap will fit nicely in a twelve-point 16mm socket, and you'll use a ratchet to drive the tap and create the threads.
An old toothbrush will clean up the threads afterwards, and the tweezers can extract any bits of plastic that fall inside the heat pump.
Put a couple wraps of Teflon thread tape around the fitting, install it, attach your tubing, and you're done.
Hope this helps some of the AquaCal owners here.
