- Oct 25, 2015
- 5,809
- Plaster
- CircuPool RJ-60 Plus
Helena,
Sorry for the delay, got busy with home build and Christmas travel. I think there are several solutions to the pool problem you're having and they are not something that can be easily addressed here because a competent designer needs to come out to make some measurements then design a solution. A skilled designer really needs to come out with a zip level to figure out the best solution. So you'll need to get a competent pool designer/repair company to do the repair. I'm sure at some price you can get a repair company to do the work or you may just need to make the pool usable by just not using the sunken area until you can get a contractor or possibly by adding a temporary elevated area to force water back to the pool. The second option may not work too well unless the pool is reasonably level. I suspect your pool design did not adequately design for the displacement of swimmers give the very small margin of error with the adjacent sunken area.
I wish I had a better solution.
Chris
Chris
