If you dont have the parts already, what parts/models/links to product would you use to do this? (the pics in this thread are gone as well)
Intex Large Strainer Replacement Part Inclduing Washer and Nut | 11236 Intex Intex Large Strainer Replacement Part Inclduing Washer and Nut | 11236 - - Amazon.com
They have a return eyeball as well, but it sucks. Get a Hayward one instead.
Thank you for the great tutorial, I want to add a second return on mine, this helps, where I will install the return it won't have the reinforced area, I will double the gasket area. hope it works.
Would it be possible to see these photos again? We have a new sand filter and I'm considering to cut bigger holes instead of using the adapters to connect to my current hoses.Hey guys,
Like many of you I upgraded my dinky cartridge filter/pump to larger sand filter/pump. I tried using the original intake and return hole with that awful "squeeze" adapter that has the plunger valves hanging out all floppy, very restrictive and not solid. So I bit the bullet and cut me some larger holes and took pics while I was at it, hope this helps those of you who are nervous about it...
Big difference in flow:
Stuff you need:
Sharpie, X-acto knife, Plunger valve, Intake & Returns that came with the new pump along with the gasket that came with each one.
These have to go!
Use the Gasket to trace the inside circle around the old hole, you'll still be inside the reinforced area:
Here is where you need to just cut slowly, make sure you cut exactly outside the sharpie line. I used my other hand to stabilized my cutting hand so i couldn't "slip". If at anytime you feel sketchy or your putting to much pressure to cut, just stop and relax then start again. Cut in a way that feels comfortable, I cut in small sections and repositioned as needed. Remember too small of a hole and you'll wrinkle the liner when you tighten and have leaks, too big and you'll have leakage as well, stay right outside that sharpie line and you'll be fine, you've got this!
Insert the head part with the gasket on the inside of the pool:
Center the threads:
Screw on the threaded nut and hand tighten while pressing out from the inside of the pool:
Screw on the return nozzle or strainer to the head base:
Next carefully thread on your plunger valve and hand tighten. Also tighten the dark grey cap under the shut off of the plunger valve, as mine was slightly loose out of the box:
Now do the same on the other side, then fill the pool and check for leaks. Tighten up things more if needed and you'll have solid, free flowing intake and returns for your new awesome pump!
Is there a substantial difference in flow using the 1.5” fittings vs using the B adapters that adapt 1.5” hoses to the factory 1.25” fittings?I didn't order any extra parts. Just what came with the sand filter. They include two "B" adapters which you can use to attach the 1 1/2" hoses that come with the sand filter to the 1 1/4" fittings on the smaller Intex pools. I ran like this for about 3 days before deciding to cut the old fittings out and use the larger fittings that came with the sand filter, as shown in the OP's photos. I'm glad I did.
I did not hard plumb anything and have no plans to do so.
All images have been removed. I need images to follow the instructions.Hey guys,
Stuff you need:
These have to go!
Center the threads:
See post #48.All images have been removed. I need images to follow the instructions.
