CPVC to PVC bonding
jeffr47
0
144
Rockville, MD
CircuPool Universal40
The adapters on my new pump are CPVC, but my existing plumbing is PVC. Do I need to get a PVC-to-CPVC adapter, or is there a glue that will make a strong bond between these two plastics?
Just found your post searching for same question. I’m hard plumbing all my equipment for first time and realized as well my check valve is CPVC. The Otey glue says works on all PVCs so I think we’re good.
I think my Hayward adapters are ABS and I did now see an ABS to PVC cement but it aleady used the regular PVC cement. I just finished tonight and starting up pump tomorrow so I guess I’ll find out.
The Oatey glue says their All Purpose Cement can be used on PVC and CPVC, but that it cannot be used to bond PVC to CPVC.
From their website:
Can I use All Purpose Cement to join PVC to CPVC?
No. It is not recommended because it takes longer for CPVC to finish the curing process necessary to complete a strong bond after the cement is applied. CPVC is also rated for hot water use which will affect cure times. PVC is not rated for hot water temperatures.
Now, whether that is a legit issue for pool applications is different. Seems like many people do it without trouble. Possibly the bond is strong enough, just not optimal. And perhaps this is a case of Oatey invoking 'cya'.
From their website:
thanks this sure does make it confusing for a DIY'er to glue up some parts lol
You're welcome? ?
Seems like most people use PVC glue to bond CPVC to PVC on their pools without trouble, so I guess we'll be fine!
If it's a critical, high pressure application, then you probably can't join pvc to cpvc.
For pool use, regular pvc glue or cpvc glue works just fine as long as you give it plenty of time to dry.
Reactions: jeffr47
Any heavy medium body glue will work. i was remiss, I only use cpvc to pvc transition primer, then I hit both with the medium body glue. Inside the Union i coat around it so there is no gap between the pvc pipe and the cpvc fitting. CPVC is used because it can withstand higher temps than pvc.
Reactions: jeffr47
I used PVC cement to connect ABS to CPVC to PVC about 15 years ago and it held up just fine. Last year I used special, dedicated ABS to PVC glue, CPVC to PVC glue and not much difference. One of the CPVC to PVC joints (with "special" CPVC cement) failed. I'd just use primer and PVC cement on everything.
