Corrosion resistant check valve?
Rodex
340
Mansfield, TX
CircuPool Edge-25
My waterfall slowly loses prime and I’ve changed out just about everything in the path besides disassembling the pump. I am now pretty Dang sure it’s this 17288 check valve - I can now hear flowing/leaking when the pump turns off.
Why would this need to be a corrosion resistant check valve? I’d like to get one of the ones that you can change the valve out without having to cut PVC (any suggestions?).
A Jandy check valve has a rubber flapper and is corrosion resistant and rebuildable.
Reactions: Rodex
I have a spa spillway and a grotto waterfall. The grotto waterfall (furthest from the equipment) will start dribbling, then stop altogether when I need to backwash or clean the filter. You might check that.
Reactions: Rodex
Searching INYO, looks like in the size I need (1.5”, 2 lb spring) has a lot of CMP options but not Jandy. Amazon listings are sparse. Any other sites to check out?
It is a crazy time for pool equipment availability.
An equivalent CMP check valve should work if you can’t wait until Jandy is available.
Reactions: Rodex
Looks like CMP has one -
CMP Check Valve 1-1/2" Inside 2" Outside 2 Lb. Spring - 25830-704-000​
Yeah the CMP one seems to be the only one readily available. I can wait - I just have to run the waterfall pump for a bit longer every day to reprime, which I’m sure puts some strain on it, but it’s been a champ through the beatings I’ve given it the past couple years.
