Cordless handheld pool cleaner
Pennypat
179
Hiram, GA
Hayward Aqua Rite (T-15)
I have a dolphin triton which works well Kay. It’s pretty random with direction. There can be a couple of piles of leaves or dirt, etc that it just misses in it’s 2 hour job.
I have a pool vacuum and a vacuum that works with the water hose and adds water to the pool while in use.
I’m looking for a portable, rechargeable vacuum to hit spots the dolphin misses. Or, to remove debris after a storm, etc.
Suggestions please.
Many like the pool blaster cordless.
I have the cheepo intex cordless version and it does ok. I use it on & inside my steps & my wrinkles around the edges of my pool.
I only use it occasionally- most of the time I just brush the steps & edges & the bot gets the rest.
For bigger stuff I use the scooper real quick.
I am also a “just run it again” kinda person. That’s why I bought a bot, so I don’t have to manually vac 😁 just press a button!
Reactions: Pennypat
My cheepo is a holdover from when i had a smaller pool - the design itself works well so I can only imagine the real deal pool blaster would be nicer & probably work even better.
