Are they safe to use? If so, how much for a 20k gallon pool and how much will my copper levels go up and best way to bring them down?
Can I add shock right after adding copper sulfate? Or which one first and how much copper? I just bought some at Ace Hardware. It's a root killer product called root.You must not be doing it right then. I have Had pristine blue for 7 years and o problems. I put In 2 lbs of shock every two weeks then I mix My own copper sulfate and water to make my own pristine blue and I add That every week as needed according to my tester. I have Never had cloudy water or algae just clear blue water. I also have never had my water tested water is clear, clean and no odor no stains on liner no green hair or suits. Yours must be different,
Haha El poolo lol. But it's so tempting!!! What if it's just one time and a very small dose?Please do not use copper sulfate. It adds copper and sulfates. Sulfate erode metal and concrete (plaster). No Bueno for El Poolo.
Copper in Pool Water - Further Reading
www.troublefreepool.com
If you like copper staining and concrete erosion, go for it.Haha El poolo lol. But it's so tempting!!! What if it's just one time and a very small dose?
The "There's no reason for" argument can be made for algae, and everything else that won't meet the pool testing standards. If you're a new pool owner you're bound to come across the "drain the pool", or "Purchase this expensive system" or, "catch a unicorn and kill it then grind it's horn and sprinkle it over the pool but only if the temperature is 65 degrees Fahrenheit in Texas I'm the summer and it's gotta be a full moon and then run your system for a week straight". What's a tiny amount of copper going to do to the plaster?If you like copper staining and concrete erosion, go for it.
Theres no reason for copper in the water so there should be nothing tempting about it.
Absolutely nothing, except add copper to the water. Theres no benefit and lots of risks/problems. You can of course do what you want.What's a tiny amount of copper going to do to the plaster?
There is no reason for algae. Funny that TFP pools don't get algae and but pools run by pool store methods do, yet TFP have no copper in them while pool store aisles are full of products with copper. Seems to me one method works while the other needs everything thrown at the water in hopes it might not get too bad.The "There's no reason for" argument can be made for algae,
I totally agree with you. Couldn't have said it better.There is no reason for algae. Funny that TFP pools don't get algae and but pools run by pool store methods do, yet TFP have no copper in them while pool store aisles are full of products with copper. Seems to me one method works while the other needs everything thrown at the water in hopes it might not get too bad.
Pool stores use ignorance to sell products to new pool owners. They sell chlorination products with CYA, then sell algaecide because the high CYA and fear of high chlorine levels can't prevent algae, then they sell purported CYA remover to maybe fix the problem they caused and will continue to make worse. The best thing a new pool owner can get is an education, but that only happens if they are willing to let go of the outdated sales pitches they got from pool stores.
What is your CH level in the pool. CH is the other chemical that you cannot remove without draining. If your CH gets too high, you can get scaling.Cal-hypo
260What is your CH level in the pool. CH is the other chemical that you cannot remove without draining. If your CH gets too high, you can get scaling.
Test your CH, and test the CH of your fill water.
Depending on those results, might be better to stick with liquid chlorine.
Oh I have no clue. I don't have my own tests yet. I was at several stores looking at some but I was confused because they all work with an app or something so I postponed that purchase til after I ask here about tests.Return the poolRX, more trouble than benefit.
You should be fine using Cal-Hypo and liquid Chlorine...just understand that when your CH gets high, the only way to remove it is replacing water.
What is your fill water CH?
