Hello, As I'm about to replace my vinyl liner in my 27' Above Ground I've been researching adding a main drain to the center of the pool for less maintenance.
The idea of less weekly maintenance is huge for me and completely negates any cost.
My concerns are likely hood of leaks.
I live in Middle TN. Our winters are cold, and I understand plugging and draining the bottom line will be advised correct? Thats not an issue as much as the initial install itself.
What do I install at the bottom around the main drain to assist in a no leak install. It can't possibly just be the vinyl itself around the drain correct?
Here's what I would be looking at purchasing.
https://www.amazon.com/Hayward-WG10...id=1496505885&sr=8-4&keywords=main+pool+drain
I'm also going to be doing a 2nd return as well so theres one at the top of the water level and the bottom for maximum circulation.
Thank you for the help and addressing my concerns ahead of time.
Edit: Is the process the same for an above ground as it is for this inground? I guess doing this it looks like I'll feel comfortable with it not leaking.
Ask the Pool Guy: 10 Step Process to Installing In Floor Cleaning Main Drains {Legendary Escapes} - YouTube
