I have an in ground vinyl liner pool that was built on the side of a hill. The pipes come out of the pool at the bottom of the pool side. So gravity was working for us because the pipes come out and go straight into the pump then filter and back up to the pool. The pipes are basically on level with the main drain. The skimmer is about 7 ft above the pump and filter.
The gravity system worked well until the lake flooded the pump and diverter valve. The water stayed over the top of the pump for 3 weeks so we had to buy a new pump. We moved the new pump from below the deck (even with bottom of pool) to above on the pool deck (about 7 ft higher elevation). The new pump sits about 18" above the pool surface.
Because the 3 way diverter valve for the skimmer and main drain is still down below we can't figure out how to install a new one without draining the entire pool. The old valve is a Compool and is leaking. I know we can plug the skimmer and return lines, but how do we keep the pool from draining when we take off the old valve to replace it?
Also which diverter valve do we need...positive or negative? We are looking at the Never Lubes.
So how do we cut off the old diverter valve without draining the entire pool? As soon as we start cutting the pvc pipe to take off the old valve, the water is going to start rushing out because the main drain will be open. How can we shut off the main drain?
Thanks
Thanks
