Clogged Dual Main Drain - How can clear it out (snake)
I'm new to pools but not plumbing. I think you should try what has been suggested for reverse flow. Buy $20 in PVC and maybe some flexible PVC to make it easier to make the joints and plumb your main pump to pull from the returns and push to the main drain. You aren't pushing against 17,000 gallons of water, water pressure works on pump head, or stated similarly, the differential between inlet and outlet pressure. At your pump (with the pump off) the difference between inlet (return) and outlet (drain) is zero psi, because they are both at the same height over the free surface of the water. If running the pump in reverse doesn't fix it, you can call a plumber and have them run a drain snake down the 1-1/2" pipe to your main drain and see what they can push out. Then plumb the pump back in and run again, cycling the pressure on and off with the switch or a valve. If they don't make any progress allow them to run a scope down the drain to see what the real problem is. I strongly suspect that cycling that main drain in reverse is going to free up the clog.
If you can take the main drain cover off so it can blow the junk out then look for rocks..Might just be a big leaf??
Also I tried a plumber and they said they can't run their expensive drain cleaner down a pool line..Too many angles and it would break it, said that machine was something like $8K.
I hired a pool company who cut the PVC lose at the pump and ran some water back using a pressure washer attachment and got it from 40% to maybe 60% flow but charged me $250..Thats when I decided to try the pump idea :)
If you are cutting PVC just cut the PVC suction off and glue in a garden hose attachment, use the garden hose, 60 psi and 10 gpm. Pressure washer will break things.
Seriously you are trying to break things now, give up before you do and have some expensive repairs
