Cleaning Glass Fencing with an Electric Car Polisher
svho
22
New Zealand
My glass fencing has quite a few water marks. I thought that cleaning with my electric car polisher (see below) might makes things easier?
I also got some instructions from AI as follows:
Using an electric car polisher to clean a glass pool fence is an interesting idea. The key is to make sure that you're doing it safely and effectively. Here are some steps and precautions to consider:
1. **Check the Tool's IP Rating**: Before using any electric tool near water, ensure it has an appropriate IP (Ingress Protection) rating for the environment. Generally, electric car polishers aren't designed to be used around water, so there's a risk of electric shock.
2. **Select the Right Pad**: Use a soft, non-abrasive foam or microfiber pad to avoid scratching the glass.
3. **Cleaning Solution**: Instead of just water, consider using a mixture of water and a few drops of dish soap. This will help break down any dirt or grime more effectively. Alternatively, there are specific glass cleaning solutions available which might be more effective.
4. **Technique**:
* Wet the glass surface with the cleaning solution.
* Dab the polisher pad into the cleaning solution so it's damp but not dripping wet.
* Start the polisher at a low speed and gently work on the glass in an overlapping motion.
* Do not apply too much pressure; let the machine do the work.
5. **Safety Precautions**:
* Never immerse the polisher in water.
* Avoid splashing water onto the motor or electrical parts of the polisher.
* Wear rubber-soled shoes to minimize the risk of electric shock.
* Use a ground fault circuit interrupter (GFCI) outlet to further reduce the risk of electric shock.
6. **Post-Cleaning**: After you've polished/cleaned the glass, rinse it with clean water and then use a squeegee or microfiber cloth to wipe off any residues and prevent streaks.
7. **Maintenance**: Always clean and dry your polisher and its pads after use to extend their lifespan and maintain effectiveness.
While using a car polisher can speed up the process and potentially give you a streak-free finish, always ensure safety first. If you're unsure, you might want to consider traditional methods like a squeegee and microfiber cloth for cleaning glass surfaces.
Anyone have any thoughts if this is a good idea or a stupid idea? :cheers:
Depending on how much you have to do it seems like it could work depending on how strong your arms are. The automated instructions are a bit silly.
Some windex and a paper towel would work better.
I have had good luck with this product (Driven Extreme Duty Glass Cleaner) for getting rid of water spots from glass. My nephew was a car detailer for a while and recommended it when he saw me trying to clean hard water spots from my windows that get splashed by kids in the pool. Just apply by hand. Also works wonders on the shower glass too!
Is the glass just dirty or is it etched from aicd raid, or have hardwater marks?
Just dirty, any cleaning method will work
Etched, you may be able to polish it out but it will be a lot work.
Hardwater marks, you just need an appropriate cleaner to make removing it easy (bathroom cleaners generally work well)
