I’ve searched, but I can’t seem to find my exact issue, it seems like most of the time the spring and brass part that screw onto the clamp are the issue, but I can screw them off no problem and I can screw them back on no problem and they hold. This is my first time trying to remove the clamp from the filter housing this year and with the nut off the clamp it’s still locked in position. I’ve tried to wiggle it. I’ve tried to shake the top. I’ve sprayed silicone all around it, I can’t get it to move. Any thoughts? I even turned the pump on briefly with the gauge up top open to see if a little bit of pressure would make it move, it didn’t. Thank you in advance!
