Choosing the right pool timer?
GhostyGhost
6
Kansas City
Hi All,
I had my old pool timer die on me last year and was going to wire in the new one this year so I don't need to manually control the pump anymore. The old timer was a digital Paragon Electric EC4004PC/208-240. I took a look at my pump and breaker and the pump is set at 115v and the breaker is a single 20A switch. Would there be any harm in downsizing the timer to something like the intermatic t101? In case it helps confirm anything I've attached a picture of my current manual wiring along with how it used to be wired and the current pump setting.
I bought a t104 already thinking I was going to need something rated for 240v but now I'm thinking it is worth downsizing.
Thanks!
A T104 timer will not work in your box since the T104 has a 240V motor and you have 120V into your electrical box.
You need a T101 timer that has a 120V motor.
If you have the 240V timer look at the back at what voltage is stamped on the motor.
There is a T103 with a 120V motor and 240V contacrs.
Reactions: Mdragger88
