Choosing a new pump
Hammond
0
107
Dallas, TX
I need a new pump. I’ve attached pics of what I have now. I also have a Polaris booster pump. Currently they are controlled with a timer.
I’m thinking of getting either a 2 speed or variable. I don’t have any automation.
I’ve been looking at the Pentair models, but they have a confusing lineup with Intelliflow, Superflow, Whisperflow…..
Is it true that if I get a variable speed pump then I won’t use the timer any more?
Do any have a way to control the pump with an app without getting full automation?
It looks like I have unions and can replace the pump without major replumbing?
Any advice is appreciated
Correct. A VS pump should get continuous power and be controlled by its control panel schedule.
Pentair Intelliflo3
Depends what you consider major replumbing.
The existing pump is marked as 1.5 hp, 10 amp with a SF of 1.5. Does that mean a new 1.5 Intelliflow would be a like replacement?
Post pics of the motor data plate.
1.5HP motor with a 1.5 SF is a 2.25 THP pump.
You should get the 3HP Intelliflo.
Those American Pool Products Ultra Flow pumps were very good, but were discontinued when Pentair bought the company. Parts are difficult to get so rebuilding that pump is not the best idea (and I usually recommend replacing the motor).
Get the largest in horsepower VSP you can to run at slower speeds for a long time to get the most benefit from a VSP.
