I need to replace the caulk around my in ground pool. I don't know whether to put sand in the joint first and then foam, or foam first. I have read different opinions on whether to use sand.
Thanks. I hve about 100 lineal feet so I don't plan on doing it myself. One person I spoke with said he would put sand in first to fill in part of the gap and then foam. I have been reading that sand is not good because it doesn't allow for expansion but maybe for this purpose it's ok. My back and knees hurt just thinking about it . I am in Southern California, so I don't have to worry about freezing weather.
DO put sand in there. Only lazy or incompetent pool people do that. And there reason for doing is cause they dont wont to take the time to seal the little voids not sealed that the Deck O seal will run down into and take for ever to fill.
One PB I talked to in So. Ca. mortars the joint completely.
