Hello we are just getting our pool up and running for the season…it was a cloudy blue so I put in some chlorine but it immediately turned brown!! Now what do I do?
Probably iron. Are you on a well? If so, get some polyfill ASAP and put in the skimmers. Try to capture as much as you can now.it was a cloudy blue so I put in some chlorine but it immediately turned brown!! Now what do I do?
ProTeam's Metal Magic and Jack's Magic the Pink Stuff (regular), the Blue Stuff (fresh plaster), and the Purple Stuff (SWG) are some of the top sequestrants. You can also find other brands with similar products, some of which are noticeably less expensive. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective.What do I use for a sequestrat should I use?
Chlorine can be expected to drop a little each day as the water warms. A regular drop of 2-4 ppm can be expected. So unless you have something to product chlorine automatically like a salt water generator, you have to manually add a little chlorine each day.Also I checked my chlorine this morning and it went down to 3!!! I was at 12 on Saturday!! Now what?
