I've had my spa for 2.5 years now, on my 5th fill. Each fill seems to bring some new mystery. The first fill was kind of a mess, I found TFP and cleaned it w/ahh-some, and switched to an SWG. Have had relatively few issues since then. A couple of weeks ago it was time to purge and refill again, did the usual ahh-some clean w/minimal results - just some small flecks of brown/green on the foam and a little bit on the walls of the tub once the jets stopped running. Did a thorough rinse after emptying the tub, and refilled. Since then, for the first time, I've been seeing a pretty rapid build of of brown scum at the water line. The build up is decreasing but I am confused how this could happen with a fresh fill, especially when it never happened before. I also developed a mild rash and I felt like my skin was maybe a bit prickly after using the tub, something else I haven't noticed before (this could also just be me being hypersensitive!). Aside from this the water is perfect - very clear, all chem levels good. If anything the Cl has been a bit on the high side. I can only think of two possible sources for the scum:
- I didn't replace the filters, did use filters that had been rinsed, cleaned w/eco soak, and dried. Maybe these weren't clearing the water properly, or actually added some gunk to it. I replaced these w/new filters yesterday so if the scum doesn't come back I'm gonna assume the filters were part of the issue.
- There was still gunk in the lines of the spa when I refilled it. I've always wondered about how to clean the lines w/out doing a full refill and dump after using ahh-some - something I'd rather avoid for time and cost reasons. How can I tell if this is the source of my problems? After doing an ahh-some purge, do people do another full fill and dump to really get the pipes cleaned out? Seems like a lot of work but maybe it's needed.
