I hadn't.... I did now though. But where should I go from here?
You can follow it now.
The first step is to rely on your own testing with your Taylor k2006 or tf100, stop getting advice from the pool store,
& use
PoolMath for calculating additions.
took 18 drops of R-0871 in 10mL. So I chlorine would be 9 ppm, and bromine would be like 40.5....
9ppm fc x2.25 =20.25 ppm Total Br
If you leave the cover open and let the sunlight in the Total Br will go down.
It is safe to use the tub once it falls below 10ppm.
The ch can only be lowered by exchanging water.
275 isn’t terribly high - ch is one of the tests the pool stores get wrong the most so test it yourself.
As you manage ph to keep it in the 7’s your ta will fall.
For most people once it gets around 50/60 the ph rise frequency is noticeably less.
If you have added the sodium bromate you now have a “bank” & you can discontinue the tabs, then be on a 2 step system & only need liquid chlorine to reactivate your bank & maintain 4-6ppm total br If you wish.
The dichlor in the tabs & granules is acidic (lowers ph) so take that into consideration when using them to shock or maintain your sanitizer levels.
