I have a 20 year old in-ground concrete pool with bullnose brick coping in southeast PA. A couple of years ago some hairline cracks opened in the joints between some of the bricks and water began damaging both the coping and the tile around the edge of the pool and the adjoining spa wall (see pics below - the water's gross because I just opened it for the season.) I've spent the last two seasons trying to find a contractor who would come out and work on things without success - nobody wants to deal with such a relatively small job. So, I'm going to give it a shot myself.
My plan is to fix the coping first, then pull off and redo all of the affected tile. Tapping on the coping, I have about 25 bricks that sound hollow and need to be removed and replaced; some of them are damaged and will need a complete replacement, but if I can salvage most of them (especially the ones with the long cuts to fit the tight curve) that will make my life easier.
So, simple questions: what mortar should I be using to reattach the bricks? Should I use the same material to fill in the joints? Should I then use a sealer to protect against water intrusion, or are there epoxy-based mortar/grout products I should use instead? I've found suggestions recommending everything from 3:1 sand/cement mix to specialty epoxy products.
Thanks!
Thanks!
