Hello all! This place has been a great resource in the past, and I'm hoping for some more advice regarding electrical wiring. I'm posting mostly to get a second opinion and make sure my thinking is correct and that I'm not missing any obvious options or things to check. Last summer I had no issues with the electrical at all. The only thing wired on the breaker was the pool light and the pump (single speed 1.5HP).
The current electrical is run from the breaker box in the house. It's wired for 120v on a 20A GFCI breaker. This summer I decided I wanted to install a SWG, so I did some research, bought the thing and got it all installed correctly. I ended up redoing all of the wiring in the pool shed to accommodate the SWG and clean things up from the previous owner (and things like an outdoor outlet was literally rusted into pieces so that had to be replaced. I put a GFCI outlet here for good measure since all the electrical from the pool shed goes through here). I got everything wired up using 12g (to match what was already run) and everything passes a basic smoke test. To recap, all I added was the Aquarite SWG and a fluorescent light. The SWG box lights up, but I haven't connected the cell or flow switch yet because we're still in the process of opening the pool. I've attached a diagram below showing the current wiring setup.
Now to the problem. The pump will turn on and run for at least several hours (i haven't been able to pin down how long yet) and then the breaker will get tripped. I didn't have issues when opening the pool doing things like vacuuming out the pool or having it recirculate while I skimmed and brushed the pool. But when I woke up the next morning the breaker was tripped. The following morning, I flipped the breaker and it all turned on correctly and ran as expected while I was getting ready in the morning. Whenever I came home from work, it was tripped again. I repeated this process several times (because we're in the process of opening the pool) and started doing research today.
I haven't checked the physical pump yet, but it seems from looking at similar models that it's likely that my pump is drawing around 19A, which explains why it might sometimes be tripping if the SWG (even in it's "Off" state) is drawing just enough to trip it (I imagine this will get worse whenever the SWG is actually on and working). I'm trying to figure out the most reasonable solution.
Here are the possible solutions I've managed to come up with and I'd welcome any additional thoughts for things I haven't considered.
Is there something I'm missing along the way that could be causing this breaker to be tripped randomly after several hours of operation? Unless I'm missing something obvious that I haven't checked yet, I'm leaning towards option 1. It would be super tedious to do and I'm not sure what to do about the 12g wiring for the pool light (because I can't access that part under the concrete deck) but it requires just rewiring existing things to a lower gauge which is well within my capabilities.
Thoughts? Thank you in advance for reading.
- Swap the 20A breaker out for a 30A breaker, but then my 12g wire isn't thick enough to be up to code, so I'd need to rerun the entire stretch to be 10g instead. Tedious, but doable.
- Swap the 120/20A breaker out for a 240/20A breaker and run 12/3 wire the entire stretch to the pool shed and rewire everything to be 240 instead of 120
- Have someone come out and install a breaker box in the pool shed and rewire everything from there appropriately. This is probably the most "future proof" option in case I decide I want to add something else in the future, although I don't have any plans to anytime soon, but it's also likely to be the most expensive because I would want to have an electrician do something that major.
- Run a separate run off another 120/20A to the pool shed. This is the least desirable because I'd like the pump and SWG to be on the same timer, and I don't think that a timer will accommodate a setup like this, but i'm putting it here for completeness.
