Bonding wire?
Raganbogan
10
Robins, Iowa
Pentair Intellichlor IC-30
I would like to add a heater bypass valve, but my existing plumbing is very tight. I might free up space for a tee if I don't need this section with a bonding wire going to it. Does anyone know if this is really needed? I have not noticed it on pictures of other Pools or at my friends pools.
Reactions: chrger1970
Yes. It's really needed to ensure that there is no volage gradient so people dont get shocked. Its code and a safety issue.
Your friends pools may have them in the skimmer basket.
Reactions: Sws
Needed? Yes. Just move it to another location in the plumbing.
If you're doing plumbing improvements, consider replacing the ball valves with high quality 2-way diverter valves.
Ok, thanks everyone for the suggestions! I may try to relocate that. I’ve got new Jandy valves on order already. Since this is my first pool, I didn’t know to ask for that when they built it.
Reactions: PoolStored
I've never seen a flow meter installed on the suction side.
Of course, based on its orientation, it's INOP anyway.
I just noticed that too….I saw it once on a HOA new pool build. County regs and the inspector called out a flow meter needed to be installed on each pump….so inspector slapped in 3 blue white flow meters on all the pumps….all on the suction side. Of course they never worked, but county signed off on the build. I got called out 3 months after completion because the pool had black algae and a litany of other issues….owner got a 20 page owners representative report documenting all the improper build issues I found.
Maybe the same builder relocated to Iowa…🤣
