Hi,
My pool is 5x10m, 89 m3 = 23.500 gal. It has 2x2 cm tiles. Since about a year, black algae has started to grow. Mostly in the edges of the floor (where the floor and the wall meet). But now it is spreading to the rest of the floor. See pictures. It is almost impossible to brush off. This is because:
So, I am now thinking of emptying the pool, using a power washer to clean it off, and then brush it with bleach several times. Most of the algae is in the deep part of the pool, so, I could put some water there with bleach, after the power washing, to keep it exposed to chlorine for a longer time.
I have read here that I am supposed to brush it and then keep it in reasonable high FC for a longer time. But washing it with pure bleach a few times should do the job as well, or even better I suppose?
I have tried to expose it to a very high FC by building a 1x1m PVC 'cover' that I would put on the floor and inject bleach below. It did work to some extend, the algae in the middle of the device would disappear (mostly) after about 15-30 minutes. But it did not work well enough, and doing the round edges like that would be very difficult.
So, please let me know what you think.
I am in Portugal, near the ocean. I have a solar heating that works very well, so my water has been warm for a long period.
Thanks a lot!!
- The pool is 2 m deep and it is in the edges.
- It is in the grouting which is a bit below the tiles, so the brush hardly touches it.
- It is usually windy here, so because of the waves you cannot see the bottom well, so, you can not see what you are doing.
Thanks a lot!!
