- Jun 24, 2021
- 15,579
- Vinyl
- CircuPool RJ-60 Plus
Would be interesting to get a thread going on the "best of the best" tips you learned from Trouble Free Pool (TFP).
The best tip I have have learned is to keep my FC high enough to protect from a high demand FC day.
Whether you are manually dosing Liquid Chlorine, using a Stenner (or other LC) pump, or an SWG, you can, and should run at the high end of the recommended FC range (or higher) to protect your pool from getting to the minimum FC for your CYA FC/CYA Levels, and avoiding algae. Since it is safe to swim up to SLAM level FC, this is the greatest "learning" I've had.
