Best ph reducer
birkesl
60
Washington, Il
I’m struggling to find high percentage muriatic acid here in central Illinois. The stuff I find is $15 a gallon and low percentage. Am I better off just buying pH reducer at Walmart or the local pool supply or are there other options that I should consider?
Do NOT use dry acid. The sulfates added to the pool water can damage your SWCG.
Get muriatic acid. Check paint stores, hardware stores, pool stores, Menards, etc.
Reactions: birkesl
