Atmospheric Vacuum Breaker on Auto-Filler Leaking
ArtP
118
AZ
Pentair Intellichlor IC-40
I have 1/2" PVC running from my house to my pool's auto filler. There is a vacuum breaker in-line in the PVC upstream from the valve (a regular PVC ball valve) to shut off the auto-fill. From reading online, it sounds like an AVB should not be subjected to constant pressure. Recently the breaker started failing and dripping water. My first instinct was to replace the o-rings or gaskets in it, but now I'm not sure it's needed, or that it's installed correctly. Does anyone with more plumbing knowledge than I know what I should do?
Here's a photo of the breaker leaking water. It drips, but there's also a fine mist coming out.
AYnd_AQjOYU7g8J1NM_ofYN9rjAGDDMm6UChiQbAop38S9C70-fMW-BA-84x0ap1YdATWnt9QzVnFv2GXscHnAeztDQZndZo3DGdKEnqIfk1Mhfn75nAoDY0_pkFinj15mH_t-FLcNaKsWKZ2Kf6cWc97_AwIeps8aFvlJXaECQstUuAn5TEAoCvpr5F7-XcMq7v7MDucN5onUNcGUQhvX3q28Kxh6kW_mMSb8cBJNRgLeQuZpZjexEQPPdPzVBgMrwno-AwTl7r09O608BfN5V3XGoDaBYQ_-Q2Ig0hhWV0JKGixwH8jGN4fNn3VVvHB4tYFlvZy0JEJZu2FluYIR_T8TFmFoIgYzMiPNF4GVkMztDQedIAA9wjI7F5yK88oX1HJr6fddkbvakFZOENjfMHqZQ8cy_7tTuGbW30Sion49EK6ulazVjBFd9SK6CPt18Z0l9sEG3gvJ6O9AbOyje0RWmjiRp1ore5waL5LcJwoQbL47cPXgm9B3UheChsYuT9T7bKzsBrnMUqmG0tYmh4iYf_FsT5zB1bj4Cqxc3GdwA9zTk0TI6lQ6lbrJV_rQJvB0f6RT9b4erVQBymqg5cMukM9pSwAVrTutlDo2fLqssA-xS868OXe2brWkNMClGbHXfs2GylGPtAUEy4SRieOfKJpnlqowKED3Mp15WMiRi6b0K4Pz047-1UFhcjuiLjUmnGPgcR7VAkZkPx0vgzz_hXBt1cv2X94VvG5jfd4ILxA_PylgIF1mYRHTLPXm-KJPe8ZN4MzduHt0otGqcChST-aZ53dxIqBCSwUxa-xTpBh1Ritu9tSmJeizkmlzdd3yROQYUWo8xY1nv-K0e0EQ0E1j-6x3fqCv8tVgBn3gsg8bzzUDYAPrd9ZsBVbQO7ZRW1mtTebLNvpjqhUIeehC-IRfZmgluEB0CTuy6jbw=w706-h941-s-no
Here's part of the manual I found for this particular breaker:
