Are these valves in the correct position?
MrBBQ
17
Ca
I had a leak in the backyard and had a leak detection company come. He tinkered with the pool equipment and not sure if he adjusted these valves. Anyways, are these in the correct position?1725717633279.jpeg
One is on and one is off. If you wish water to flow through the pipes, you need to turn the upper one on. For that type valve, the handle is parallel with the pipe when on.
BBQ,
Water should come up and into the bottom of the backflow preventer and then come out on the horizontal pipe to your auto fill system.
The valve on the horizontal pipe is in the Off position.. It should be in the On position.. In line with the pipe.
The leak detection guy, even though they were recommended , seemed to be useless for my issue. I can’t seem to diagnose the leak. The water company has told me I have 24/7 water use.
I now notice this coming from the valves now, it’s leaking from the top plastic part. My auto fill is not working either, 0 water is coming from it. I had water leaking from planters, thinking it could be irrigation. Water line at the main is on
