- Apr 15, 2021
- 19
- Vinyl
- Jandy Aquapure 1400
Hello,
Would you please kindly assist in diagnosing my SWCG problem?
I recently purchased a house that came with a pool. I am a noob and my apologies if I am not using the correct lingo.
I have a Zodiac Aquapure PLC1400. When the pump turns on, the unit seems to start producing chlorine, but after a short few mins, the orange service light turns on and the error code 120 is shown. (sometimes 121 as well)
I followed the Aquapure troubleshooting workbook and I would like to report the following:
Transformer Voltage tests
All three tests passed.
PIB DC Voltage
Both tests passed
Testing voltage at the cell
I set the chlorine production to 100% and started watching the voltage Something tragic happens here: the voltage started from around 18.9 and increased quickly to 45 and beyond where my voltmeter shut down. I recorded the measurement process for your reference here:
Cell Voltage and Current
test 1 for green and black: to pass the test voltage should be between 22 to 28. I got 8.6
note: my probes were too thick to reach the green and black plates. I measured it from the wires that were connected to green and black plates
test 2 for 120mVDC:
the expected value was 100 to 145. My voltmeter was showing a negative value. -25
Other important information
Questions:
based on the flow chart provided by the workbook it appears that I need to replace the cell. However, based on the cell voltage and current test instructions, I need to replace the PIB.
Which one should I do?
Also, I question the validity of my cell voltage and current. the workbook says that Aquapure should be set to 100% and should be producing chlorine. How are we supposed to measure the voltage from green and black, while the cell is generating chlorine? the only way to measure the voltage is to disconnect the wires from the board or from the extension wire to the cell cord, which was my method for the measurement. in that case, the unit is not producing chlorine.
Thanks in advance for your help.
PIB DC Voltage
Both tests passed
test 2 for 120mVDC:
- the cell cord doesn't have any corrosion
- the cell cord is firmly connected to the unit
- I acid washed the cell plates. it was very clean, to begin with. I followed the instructions in the manual just to be safe.
- the cell manufacturing date was 2014. I believe it was also installed in the same year. Based on the manufacturing date, It seems to have reached the end of its life.
- the salinity is around 3500 reported by the sensor. My test strip also shows the same range
Questions:
