So I stopped using my Apera PH60 tester for pH readings because the readings were crappy compared to my Taylor kit reading. I realized today, it's user error. I had been following the Quick Start/Use laminated card that comes with the unit, but I also noticed that that laminated quick guide doesn't say ANYTHING about proper storage and well, I was not properly storing it . I found out that the probe should be stored damp/wet with the cover/cap fully closed to keep the tip from drying out. I was not doing that and my unit seemed to get less responsive over time, even calibrating it didn't help.
The good news was, I foiund that cleaning the probe in the 3M KCL Storage Solution for a couple of hours, and then recalibrating the probe (7.0, 4.0 and then 10.0) totally fixed all my issues. Not only does it read correctly now with both the Taylor and TF-PRO pH blocks (yes, I have to use both, cause I need to double-check things being color blind) but the PH60 also reads SUPER fast now.
I bought this on Amazon to get me a proper cleaning and calibration and couldn't be happier: Amazon.com
Now I know to store the probe tip with some moisture on it and in its protective cap/cover to keep the tip from drying out. Passing this along for others who might struggle with their Apera PH60 meter.
(I use mine because I'm color blind and color based pH reading tests have been a real struggle for me in the past, though I think I've managed to train my eye properly and have gotten way better).
HTH someone else.
HTH someone else.
