Is there any way to stop (at least temporarily) a small leak from an old gate valve without dismantling the valve/piping assembly?
Recently I've noticed both of these gate valves leaking at the interface between valve and piping (as best I can see). I believe one controls return flow and the other controls flow to an old "whip" cleaning system. I've never opened/closed them since I bought house about 5 years ago. They seem to be locked into position from misuse from previous owner. Pool works fine with where the valves are at. The plumbing & valve layout from skimmer to pump is goofy and needs to be re-done but I'm not ready to do that and replace the pump/filter for a few more months. Thought I may get by with something for leak at least temporarily. Thanks.
