- Jul 3, 2020
- 111
- Vinyl
- Pentair Intellichlor IC-40
I am looking for recommendations on what ingredients to look for/avoid in pool antifreeze. I see Walmart has a great price and it claims is "non-toxic." It does contain water, propylene glycol, glycerin, corrosion inhibitor, dye.
Home Depot has two options:
One contains PG but is glycerin free. Is there any reason to avoid glycerin:
Other contains ethyl alcohol which sounds like I want to stay away from:
Thanks for the input!
PRIME GUARD 128 fl. oz. PG Formula and Glycerin Free -50°F RV Antifreeze 95006 - The Home Depot
PRIME GUARD minus 50°F RV and Marine Premium Antifreeze is a propylene glycol (PG) based product blended with a proprietary additive package. Our patented Acra-Blend Process ensures that every bottle is blended to exact specifications. This is critical as this product is typically used to...
www.homedepot.com
PRIME GUARD 128 fl. oz. Ethyl Alcohol -50°F Universal Non- Potable RV Antifreeze 95806 - The Home Depot
PRIME GUARD minus 50°F RV and Marine Antifreeze is a premium winterizing formulation safe for use in all types of potable water and plumbing systems. This ethyl alcohol formula is safe on copper, brass
www.homedepot.com
