- Jul 7, 2022
- 44
- Plaster
- Pentair Intellichlor IC-20
I have an 1.5HP 240v Air Supply Silencer Air Blower for use with my Spool. I have a total of 7 jets throughout the pool and they work fine. When I select the air blower via the ScreenLogic app, I hear a click on the automation panel, the check valve in the pipe leading to the air blower visibly engages through the see-through window, but no additional air is produced, so it is getting power. The air volume on the jets remain the same. I made the selection directly from the automation panel and same result. I flipped the breaker twice, nothing. I removed the lid looking for anything obvious, nothing. I tugged on all the wiring, nothing loose. I did NOT run the air blower with the lid off to confirm any movement because I didn't know if that was going to cause some kind of suction issue.
Admittedly, I don't use the air blower often or even the jets, but the entire pool and its equipment is only 2.5 years old. I contacted the company and they said, "Check the voltage because it sounds like it is working on 120volt instead of 240volt."
I don't know how I would test this....
Thank you for your time and assistance.
