Hello I’m a first time pool owner on a house we just bought. I noticed the spa jets don’t have any bubbles a lid my neighbor told me he can’t find the air intake that produces the air? Any ideas? Here is my equipment.
I hope not. Is there a way to add without trenching new pipes?
No they are just pvc stubs in the walls of spa. Nothing is attached to them. So basically you can shove your finger in it and it’s just smooth pipeAre they adjustable? Can you turn them to change the flow? They appear to be spa jets.
Thank you. I took the cap off of that line and appears to have water in it at ground height. It did see to get a little air in jets for about 3 seconds then back to normal... Is there anything I can do with this pipe to help? Is it normal to have water in it? Any idea how to drain if not?Try removing the white cap from the line Allen mentioned. It looks new and doesn't even look like it's glued on. That would be the first place I would check.
Did you have the system in spa mode (full suction from and return to spa) and the pump at high speed?Thank you. I took the cap off of that line and appears to have water in it at ground height. It did see to get a little air in jets for about 3 seconds then back to normal... Is there anything I can do with this pipe to help? Is it normal to have water in it? Any idea how to drain if not?
yes I did. Then I realized you may have been talking removing cap on the little 1 inch line stubbed out of ground correct? Not the two inch line that I sent in pics? I may have done wrong pipeDid you have the system in spa mode (full suction from and return to spa) and the pump at high speed?
Sorry if I repeat any previous questions, just got on this one.No they are just pvc stubs in the walls of spa. Nothing is attached to them. So basically you can shove your finger in it and it’s just smooth pipe
Nothing protrudes out its just eye balls. 1/2 I would say and you can feel smooth pipe all the way with pointer finger.Sorry if I repeat any previous questions, just got on this one.
So you can see the end of a pipe in the spa wall, or is there a flange about a half-inch thick that protrudes a bit out from the wall?
Is there an eyeball or nozzle (directional adjustment like a pool return) in the return?
How big is it? 3/8-1/2 sounds like a nozzle. You could not get your finger into a 3/8, and only the tip in a 1/2. So how far back in there are you able to feel smooth pipe?
You said you saw air for a moment when you removed the cap but it stopped. How long did you run it that way?
The 2" pipe sure looks like a blower connection. If they are jets (as pictured before) they will still pull in air even without a blower, but it may take quite a while to pull all the water out of the pipe to get some air to it. It is normal for that pipe to fill with water when the jets are off, as it uses a venturi to create the suction. That's why there is often a check valve on the air intake or blower line to trap the air in the pipe.
If it has those jets, they are adjustable. They can easily become stuck from scale and not move anymore.
Would it be possible to get a close-up pic of the jet?
