- May 8, 2013
- 21
Hi My name is Michelle, I put a new liner in my above ground pool 16x32 oval, there were two Air bubbles that popped up at the end of the season. Note I have the vinyl bottom and styrofoam cove and padding on the wall it was harder than it looked and never want to do that my-self ever again!
Anyway, when I took the cover off a week ago there is one bigger bubble closer to the edge this time. read some of your post that suggest to use a plunger to get it up the wall. However my pool is almost full of water will this still work or do I need to take it down to 1/4 or so? I do see where the other air bubble went down and there are a few wrinkles which does not bother me you can't really see them, But is it okay to leave them?
Thank You
Michelle
Thank You
Michelle
