Advice re a new pool heater
Look at Raypak heaters. You don’t say what BTU your old heater is and if you get a larger one check your gas service can handle It.
Raypak has larger commercial pool heaters if you can fit it in...
Hayward has a 500K BTU heater ...
Ray pak vs pentair mastertemp both are 400k btu. Any preference?
They are both good. I have had Pentair MasterTemps. Many folks here are happy with their Raypaks.
They are different designs. MasterTemp uses a forced air blower vent system to power airflow through the combustion process. I think it is smaller and more compact. The Raypak 406A uses a more traditional natural heat upflow vent process. I think it is larger then the MasterTemp. So if siting and venting and airflow are issues in your location one may be better then the other.
Check on the warranty you will get with each depending on where you buy it and how you have it installed.
Figure out who you would turn to for service and repairs. That may be the deciding factor along with warranty.
