- May 23, 2015
- 25,688
- Plaster
- Pentair Intellichlor IC-60
So the other day I was out at the pool and noticed a small stone piece had popped off from the stacked stone facade around the spa -
It fits perfectly back into place and the two bonding surfaces are clean and smooth. It's an easy fix but I just wanted to see if there was the "perfect" adhesive recommendation for the job. All it has to do is bond two pieces of stone together, go on thin enough to not be noticeable and last in the excessive temperature variations we get in Tucson (freezing in the winters and 115F in the summers).
All suggestions are welcome.
