Solid granular stabilizer is best added by placing it in a sock or nylon and hanging that sock in front of fast moving return(s). Shaking and squeezing the sock while in the pool water will help the stabilizer dissolve faster.
Alternatively, the sock can be placed into the skimmer basket BUT it should only be left in there if the pump is continuously running and not turned on and off by a timer. CYA is acidic when it dissolves into water and so it is not a good idea to leave the sock in the skimmer without the pump running.
Pouring granular CYA into the pool directly, or into the skimmer as recommended on stabilizer bottles, is not recommended as it takes a long time to dissolve and the granules can sit against the pool surface creating locally low pH levels.
The pump should be run for 24 hours after adding solid stabilizer and you should avoid backwashing/cleaning the filter for a few days if stabilizer was added to the skimmer.
www.troublefreepool.com
