2" pipe connections
tcat
1,778
Austin, TX
CircuPool Edge-40
I'm getting ready to redo my plumbing to move my SWG from before to after my heater. I've got most figured out, but need to connect a valve (opening facing down), to the heater ( opening facing out). Heater opening about 36" left of valve opening, which sites about 8" back.
Do I use 3 90's, or 2 90's and 2 45's, or 1 90 and some 2" flex hose? The hose is expensive, so rather use fittings. I'm probably overthinking it.
Do you already have a bypass installed? Any ball valves you can replace with 2-way diverters?
Yes I have 2 Jandy 3-way for bypass. Going to reuse one and bought a Pentair 3-way. Decided 2 90's and one 45 for the offset will work. Ordered fittings today from PVCfittings (much cheaper than HD). Main reason is my heater is 10 years old and if I need to replaced it, I need to add a couple unions and get the SWG on the "out". Also going to replace 2 ball valves going into the pump with one 3-way. Probably don't "need" to do any of this, but I'm retired and bored, so why not. Will be all set for a new heat pump when it quits. Turned it on 4 days ago and it's up to 80!
Reactions: pjt
