- Jun 1, 2023
- 63
- Fiberglass
- Hayward Aqua Rite (T-15)
- 4/22 start to open. Water temp 58F. Lotta worms in the sweeper this year. Very cloudy blueish water but not green—could not even see the sweeper when it was on the bottom. Used Polyquat at close in Oct (with relatively high FC if I remember correctly).
- 4/22 to 5/8 CYA 20; SLAM at 10 FC. Started at 7.2 pH. Slow progress but eventually got clear water, but could never get OCLT to pass. Usually, it was a 1-2 FC loss and 1 CC.
- 5/9-5/21 Temps & sun starting to be more consistent, so decided to bring up CYA to 50 and continued to SLAM at 20 FC. Water still clear and still failing OCLT at about the same amount as above. Got tired of buying LC and lax on OCLT rigor so supplemented with SWCG during the day; some of this was to make sure everything was working OK for the season. During this time, I also bought Taylor K1106 Phosphate test kit; tested at 4000ppb. Was wondering if this could be contributing to the FC loss problem. But I had added Jack’s purple stuff late last summer, so this could affect the phos level (?). I did not treat for phosphates after the 4000ppb…don’t want to deal with that unless I have to.
Have removed and cleaned every piece of white plastic in the pool and no signs of algae. Also cleaned and sprayed the auto cover well with chlorine/water mix, as that gets pretty gunky. Underside of autocover is clean.
Had a couple air leaks that just got fixed Saturday. One was the 2” PVC between filter and heater. The other were Jandy swim jet lids and main pump lid needed Teflon lube or a new o-ring. No leaks now.
Water tests last night: FC 19.5, CC 1, CH 400, TA 70, CYA 50, Salt 3800. pH was 7.2 when I started this a month ago.
Questions: I know passing OCLT should be achievable, but wondering if the spring air stuff is a hindrance to that? I don’t think the air leaks would contribute to FC loss? I would like to raise the CYA to 70-80 in the next few weeks before it gets hot, but then SLAM gets more inefficient. Any advice? One month of SLAM with no change in OCLT seems odd.
Thanks for any help!
