N NYsteve Active member Jun 15, 2020 25 Copake, ,NY Apr 27, 2024 Add bookmark #1 I opened my pool and mice made a nest in the corner of my step. The finish is stained. Looking for advice on how to clean it.
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 53,660 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Apr 27, 2024 Add bookmark #2 That plaster looks old so you need to go easy on the cleaning or you will ruin it. Do not pressure wash it. I would first try SLAM level chlorine for a while. If that does not work I would try hand sanding an area of the plaster with 80/100 grit wet/dry sandpaper or polishing pads like described in Plaster Installation and Maintenance - Further Reading
