T tbl Member Apr 18, 2024 9 phoenix Pool Size 13750 Surface Plaster Chlorine Salt Water Generator SWG Type CircuPool Core-35 Apr 18, 2024 Add bookmark #1 Hello, Can someone tell me where I could install a SWG? It doesn't look as straightforward as other's set up in this forum. Thank you in advance.
Jimrahbe Mod Squad TFP Expert LifeTime Supporter Jul 7, 2014 33,133 Bedford, TX Apr 18, 2024 Add bookmark #2 tbl, The SWCG would normally go between your heater and your automated return valve. Thanks, Jim R.
T tbl Member Apr 18, 2024 9 phoenix Pool Size 13750 Surface Plaster Chlorine Salt Water Generator SWG Type CircuPool Core-35 Apr 18, 2024 Add bookmark #3 Thank you!
T tbl Member Apr 18, 2024 9 phoenix Pool Size 13750 Surface Plaster Chlorine Salt Water Generator SWG Type CircuPool Core-35 Apr 18, 2024 Add bookmark #4 Jimrahbe said: tbl, The SWCG would normally go between your heater and your automated return valve. Thanks, Jim R. Click to expand... Jim, I have a follow up question. That stretch of PVC is only 15” Would i have to do something like this user did? Last edited: Apr 18, 2024
Rancho Cost-a-Lotta Gold Supporter Silver Supporter TFP Guide Apr 10, 2018 5,266 Rancho Cucamonga, CA Pool Size 18375 Surface Plaster Chlorine Salt Water Generator SWG Type CircuPool RJ-45 Apr 18, 2024 Add bookmark #5 tbl said: Would i have to do something like this user did? Click to expand... Something like... Reactions: Jimrahbe and proavia
