I'm a little sad and concerned here... Topped off for the start of the season and checked levels.
My Taylor CYA test showed levels below readable, i.e. the black dot was clearly visible with the test all the way full of water. I read that temperature could affect the test, so I re-did it, keeping the bottle in my pocket to warm it up while conducting other tests, and then checked again with the same results.
Tested the salinity. Checked with PoolMath, added the prescribed amounts, admittedly not precisely. I added what I thought was 3/4 of a full 40lb bag of salt. For CYA, worked off the assumption that my CYA level was very low. I'd had what I thought was half a 4lb bag left of stabilizer. dumped it in.
Now my levels are off the charts. Where did I go wrong..? The salt seemed on par with what I thought I'd have to add, given that I drained below the return, and I'd never topped off any splash/spill loss from last season, when I first filled and added the prescribed amounts. Perhaps the CYA was foolish and I should have thought about the fact that I was re-adding pretty much the same amount as what I'd added in last season into virgin water. Well, obviously I went wrong by not dumping smaller amounts in increments, but how are these numbers so drastically off?
And is it ok to have CYA and salt levels so high? Particularly concerned about the salinity wrecking anything and I'm likely to get a pool heater too which I also don't want to subject to too much corrosion abuse.
