- May 19, 2011
- 66
- Vinyl
- Hayward Aqua Rite (T-15)
Long time TFP member here and i have never had any issues with my pool since using these methods… I have always had that crystal clear and sparkling water. Well I’m having an issue now and can’t get it figured out. We had a lot of pollen down here in south Texas this year and a lot falling from my neighbors tree into my pool. I was out of town for work for awhile and couldn’t tend to the pool to keep it clean. It never turned green but there was a lot of debris on the bottom. I also Found out my wife used 4 bags of CalHypo shock in the pool while I was away. Kinda my fault I wasn’t specific when I told her to keep the chlorine levels high (I didn’t specify how and the pool store got her) Long story short I got it all cleaned out and it created a lot of cloudiness in the water so I decided to start a SLAM. I started the SLAM on 4/10 and kept on it hard every hour relentlessly. On 4/13 I passed my OCLT did not lose any chlorine overnight. I still had 0.5 on my CC but figured that passes. My problem is that even after running my pump and filter 24-7 It’s still a little cloudy and I can’t get it crystal clear. Here are my current Readings
FC - 4
CC - 0.5
pH - 7.6
TA - 100
CH - 370
CYA - 30 (Will be raising as soon as it’s ready)
Borates -30
Could the sand in the filter need to be changed? I put new sand 3 years ago. Please let me know if there is anything I’m missing. TIA
FC - 4
CC - 0.5
pH - 7.6
TA - 100
CH - 370
Borates -30
