Sta-Rite Backwash
SteveK52
253
Taylors South Carolina
As I was doing a backwash on my Sta-Rite DE filter yesterday, I was reading the backwash instructions on the filter and they said to rotate the valve to backwash for 1 minute then to rotate the valve to filter for 20 seconds and repeat the procedure 3 times. I have always rotated to rinse following each backwash. Which is the proper method?
The problem with their procedure is whoever wrote it tried to cover the operation of both a MPV and Slide Valve in one procedure.
They are very different and a Slide Valve does not have a RINSE setting, only BACK WASH and FILTER.
So they ignored what an MPV can do and said return the valve to FILTER.
I would continue to use RINSE instead of FILTER.
This is from the Pentair MPV manual.
FILTER returns the dirty backwash water to the pool.
RINSE returns the dirty backwash water to waste.
I would rather send that water to waste.
  • hiflow-side-mounted-backwash-valve-manual-english.pdf
