- Apr 28, 2024
- 16
- Vinyl
- CircuPool RJ-45
I’m getting a 24 ft Radiant pool installed in a couple weeks hopefully. I’ve decided to use a SWG with help from the site. Couple questions:
1. Should I use all 2 inch PVC and reduce at pool and pump where it is 1 1/2”?
I’ll take any suggestions on plumbing I figured to put a ball valve after the skimmer and at the inlet and then some unions
2. Unfortunately, due to the layout of my yard and deck/ patio, the pool equipment kind of needs to be placed somewhere around the south and west side of the pool which is where the prevailing winds come from. How close should the skimmer be located to the equipment without messing up the pump output? I attached some pump info. If the skimmer is placed with the wind at its back, is it that much of a problem?
